Gas tank troubles... - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-26-2003, 09:57 PM
Meangreen's Avatar
My gas tank is acting up. The problem is that one day i filled it up with gas and now the gauge inside the car doesnt work anymore?! My guess is that the float is messed up. Its a 71 Chevelle so its kinda old. Any ideas on how to free it up or something
Old 06-26-2003, 10:23 PM
Stinky's Avatar
Unscrew the straps drop the tank and theres a kind of ring that retains the sending unit. Turn that to the left i think, pull out the sending unit and replace it. Make sure the wires didnt come loose before you pull the sending unit out though, it may be as simple as that.
Ive gotta 69 GM, so it should be set up the same way.
Old 06-27-2003, 12:19 AM
Definitely check the wiring first. Old Chevys are notorious for having weird gas gauges. The tan (light brown?) wire that goes to the sending unit can ground out or come undone, causing the gauge to read strangely.
Old 06-27-2003, 08:35 AM
Meangreen's Avatar
i will try that. It sometimes works bu tthen other times it just goes way above full and doesnt work but if i lke hit the gas or brake real hard it will go down then back up.
Old 06-27-2003, 10:30 PM
Stinky's Avatar
You dont need no stinkin gauge, do like me and keep track of your miles and listen to the swish. Til' you get the "ear" for it, best keep some walkin shoes in the Rod
Old 07-01-2003, 05:16 PM
46_stvblt's Avatar
Try running a ground wire from the tank to the frame. When the guage is acting weird it is sometimes just a grounding problem..Try the ground first before you drop the tank...GlennK
Old 07-01-2003, 10:18 PM
Meangreen's Avatar
Where do i ground it?
Old 07-02-2003, 03:51 PM
46_stvblt's Avatar
Run a wire from the lip of the tank to the frame. Use a battery operated drill and drill a 1/8" hole in both the lip of the tank and the frame and run the wire. Make sure you clean the metal before attaching wire...........GlennK
Old 07-07-2003, 03:29 AM
Try it with alligator clips first before you drill into the tank. Does your sending unit have a ground connector on it?
