Gas trimmer smoking on startup - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-25-2013, 07:33 PM
mitmaks's Avatar
Last journal entry: Grille
So I have this Troy bilt trimmer for 7 years now and its been smoking at startup, Otherwise it runs great, just did valve adjustment. It's 4 cycle so I don't mix oil with gas. I do run 10w30 oil in it, recommended is 30w non detergent. Would this cause it to smoke at startup?
Old 11-07-2013, 11:28 PM
If you store it with the crankcase facing down, does it still smoke?
Old 11-07-2013, 11:42 PM
Speedshift_Sam's Avatar
Mekanicus Automotive Group
down, always down.
Yep, common issue indeed. Most smoke a little anyway because the valve seals wear down after a few years and start leaking, just like an old car. They sit overnight, what little oil is left in the rocker box bleeds into the cylinder, lo and behold, smokes on startup. I wouldn't worry too much, unless it smokes like a mosquito sprayer.
Old 11-07-2013, 11:47 PM
Right...he's had this one for 7 years now, so the seals will be quite hard and inflexible.
Trouble is with most of these seasonal type tools is that they just don't get used often enough.
Old 11-08-2013, 11:36 AM
mitmaks's Avatar
I store it with engine upside. I might switch to straigh W30 and see if that helps it.
Aspiring trimmer, introduction and a few questions Igorsgonemadd Interior 12 10-25-2012 12:49 AM
Canvas maker looking to turn into a trimmer GregPGH Introduce Yourself 1 10-04-2008 06:30 PM
Miss Jaycee: uk based trimmer missjaycee Introduce Yourself 3 10-13-2007 10:40 AM
smoke at startup davidbull Engine 10 12-27-2004 10:06 PM
AV Gas For My Smoking Big BLOCK mr_chickenhead Engine 5 08-08-2002 11:18 AM
