Gasgacinch - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-14-2011, 12:15 AM
001mustang's Avatar
Gasgacinch
planning to install intake manifold today.
edelbrock says to use gaskacinch on head side to prevent intake gasket walk, etc.
as things go...have not found gasgacinch locally...hate to wait for mr post man again.
any other gasket sealers work well w/ Steel Laminate Printoseal gaskets and aluminum intake?
Old 03-14-2011, 01:08 AM
willowbilly3's Avatar
Last journal entry: Body mods
I have always used the red Permatex high-tac. It is an aerosol. Spray it on and let it dry pretty good before sticking the gasket down.
Old 03-14-2011, 03:02 AM
malc's Avatar
Living At The Speed Of Life
I got a can of it very quickly from Amazon.com.
Iīm in Europe.
Old 03-14-2011, 04:56 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
3-M weatherstrip cement.
Old 03-14-2011, 05:30 AM
345 desoto's Avatar
Location: Skaneateles, NY Summer/Port St.Lucie, FL Winter
What COBALT327 said...and I'd REALLY reconsider which place to glue the gaskets, too. Personally I'D glue them to the intake. That way, if you ever needed to scrape/replace the gaskets, it's much easier to scrape the intake. Not to mention easier to get the residue/crap out of the intake rather than have it fall into the ports...
Old 03-14-2011, 10:20 AM
001mustang's Avatar
I used permatex brush on high tack last time on sides.
used clear rtv on ends; no cork.
was leak free for roughly 7 years then developed a very slight weep at front corner. pretty good; not perfect.
i am interested in the spray but i like idea of putting something on head also not just gasket?
Old 03-14-2011, 10:25 AM
001mustang's Avatar
is that gas resistant? i thought it was but some say its not.
is it pretty hard to remove? i know it is plenty fun to remove from body panel.
i have no doubt it will stick.
Old 03-14-2011, 10:27 AM
001mustang's Avatar
Iīm in Europe.
do you like it?
Old 03-14-2011, 10:32 AM
001mustang's Avatar
hear ya...know all about that falling residue....
Old 03-14-2011, 10:38 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The cement is used to hold the gasket in position only- not as a sealer. I use a dot at three places across the gasket, not all over the gasket or surrounding the ports or water X-over, etc. Just to hold it.
Old 03-14-2011, 11:14 AM
Irelands child's Avatar
Gaskacinch is nothing more then repackaged or relabeled contact cement (think the flammable DAP from a big box store). It looks, smells and acts/works exactly the same. I bought a can when I replaced the fuel pump eccentric - a waste of money when you can buy a quart of DAP for the price of that 4oz can. I used the DAP for years then thought I would go "pro level" --- not!!
{Now let the flames rise }
Dave W
Irelands child
Old 03-14-2011, 01:19 PM
malc's Avatar
do you like it?
Served itīs purpose, itīll probably be a looong time īfore the cans finished up.
Old 03-14-2011, 01:54 PM
001mustang's Avatar
i have weather strip adhesive...will consider dap contact cement. i think dap is easier to work with and weather strip adhesive is stronger.
plan to use adhesive around bolt holes to hold gasket in place. problem is i like to place intake manifold on gasket so it dries flat; but gasket may shift if adhesive not yet dry. sounds like the weatherstrip or contact cement will work good if i allow adhesive to tack dry before applying rtv around ports.
plan to use rtv silicone on every surface around ports.
plan to discard cork rail gaskets and use 1/4" rtv bead on rails plus 1/8" rtv on intake above rails.
plan to seal threads w/ pipe dope or TEFC tape or permatex #2 or permatex brush on high tack? i like thread sealer that can be tightened after heat cycle.
will use guide pins to promote accurate intake seating.
Thanks for the help
Old 03-14-2011, 04:22 PM
001mustang's Avatar
huh...rtv silicone is not recommended for gasoline applications.
may use rtv from water ports to rail and high tack on fuel ports.
Old 03-14-2011, 04:43 PM
You can also use indian head. I used that on mine and that stuff works good. You can also use the permatex high tac as well. Either one will do the trick for you wanting to use it for. I use permatex right stuff gasket maker around the water ports on the cylinder head side and nothing on the intake side since the felpro gaskets I used had sealing strips already made on the gasket so did not have to use any there.
Eric
Permatex High Tack same as gasgacinch? brian400ex Engine 4 02-13-2003 07:13 PM
