Gasket adhesive - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-12-2013, 03:18 PM
Gasket adhesive
Would like recommendation for a gasket material that is easy to remove and does not seal to the point where the gasket is destroyed. For example needing to remove valve covers more than once for solid lifter adjustments. Thanks for any recommendations.
Old 05-12-2013, 06:49 PM
Glue the gasket to the valve cover with your favorite yucky pucky and grease the other side of the gasket.
Old 05-12-2013, 08:38 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
I second Tresi's post. I have a 1" spacer under my BBC valve covers and use RTV black on the under side of the spacer and on the valve cover (second) gasket. I sit them on a flat surface with weight on them overnight. Works great.
Semper Fi
Old 05-13-2013, 08:06 AM
Why not use a reuseable rubber type gasket?
Old 05-13-2013, 08:45 AM
The rubber gaskets are okay, and can be re-used several times. So can the composition ("cork") if glued as described, and not left tight for extended periods (street). Beware of trying to remove them from the cover if you use weather strip adhesive. It works, but not recommended. A modern "ultra" RTV is prefered.
Many companies are offering "hard" valve cover gaskets today. They're a metal center with a neoprene ("rubber") coating and can be re-used MANY times. If you have cat aluminum or heavy steel covers, these would be the choice.
Jim
Old 05-13-2013, 05:46 PM
Thank you for the useful responses.
Old 05-14-2013, 05:49 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Hylomar Universal Blue is a non hardening sealant that may allow disassembly w/o gasket damage caused by the sealer bonding the gasket to the part. That's not to say the gasket will always be reusable; things like the amount of torque applied and length of time the parts are assembled and number of heat cycles can affect most any sealer. But for the most part, Hylomar fits in the "can disassemble" category. Much more so than RTV or traditional Permatex 1-3, for example.
Old 05-17-2013, 10:44 AM
Hylomar is some cool stuff. Developed by Rolls Royce, its currently made by Valco out of Cincinnati OH. I prefer their stuff to loctite and permatex when possible.
Old 05-17-2013, 09:00 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I recall the first time I used it (bought in haste, thought it was RTV), I thought it had gone bad- no "skinning" after waiting the usual time for RTV to skin. Read the de-structions, and used it as it was supposed to be used and worked fine. Was a fan thereafter.
Should I use a gasket sealer on a .015 shim head gasket? Caprice Sleeper Engine 2 08-23-2012 07:46 AM
Oil pan gasket and timing cover gasket, install? 39chevy Engine 2 07-23-2012 12:04 AM
Head gasket thickness, Gasket or Shim? rollie715 Engine 6 04-25-2012 03:15 PM
gasket maker for phenolic 4 hole gasket ? truckboy61 Engine 8 07-28-2011 09:44 AM
best adhesive on intake manifold gasket??? 29A Engine 24 02-01-2007 11:49 PM
