gasket alignment - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-08-2012, 04:31 PM
gasket alignment
Hi,
Just offered my felpro head gasket to my procomp heads all holes align up perfect,except 2 which are half hole out! Think they are 2 3/8 oil return holes? Anyway shall I open up gasket hole all leave it as it is?
Hope its not a procomp thing!
Dave
Old 08-08-2012, 06:30 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by dave350v8 View Post
Hi,
Dave
As long as it is an oil return drain hole, carefully cut it out to match.
Old 08-08-2012, 06:43 PM
Will do,does this happen sometimes? I thought felpro would be accurate,the rest of the holes are perfect,including the dowel holes,just hoping its not the heads being drilled wrong! Will have another look tomorrow,they are slightly smaller than the head bolt ones.
Thanks
Old 08-08-2012, 07:36 PM
Richiehd's Avatar
JS-70
If you feel better you can radious both the holes in the block and the heads.
Old 08-08-2012, 10:13 PM
How do the gaskets match the block?
PatM
Old 08-09-2012, 12:50 AM
Hi Pat,will be trying gaskets on block tomorrow still got old heads on!
Oil pan gasket and timing cover gasket, install? 39chevy Engine 2 07-23-2012 01:04 AM
Head gasket thickness, Gasket or Shim? rollie715 Engine 6 04-25-2012 04:15 PM
gasket maker for phenolic 4 hole gasket ? truckboy61 Engine 8 07-28-2011 10:44 AM
Mr Gasket Ultraseal Head Gasket's 406 ss monte Engine 4 05-03-2008 09:19 PM
gasket maker instead of flange gasket? Hogwild Transmission - Rearend 3 03-09-2008 03:18 PM
