Gasket brand recommendation - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-16-2007, 06:49 PM
chevy_power427's Avatar
Fuel flows through my veins
I'm looking for advice on different gasket brands. I have a worked over 355 sbc that i'll be pulling out in the next 2 weeks. I'll be replacing the head gasket and all. I used the fel-pro head gasket supplied with the full engine kit, nothing performance, it was a blue one permatorque. Since my engine is far from stock (10.75:1 comp.), I want to feel safer with something better, not that I had problems, but since I'll be replacing it, why not upgrade. I was thinking about Corteco. Tell me what you think, and part numbers would be good too. Thanks!
Old 12-16-2007, 07:08 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
I like the Felpro Permatorque myself.
Old 12-16-2007, 07:56 PM
Even for performance applications?? What do you use the on. Anyone used Mr. Gaskets Ultra seal?
Old 12-16-2007, 09:39 PM
Greg T's Avatar
www.krusinklassics.net
Nothing but Fel Pro here.
Old 12-16-2007, 09:42 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
I'm a fel pro guy. It sounds cliche since everyone uses them, but there's a reason for that. They are really that good.
I've used ROL gaskets with very good success as well. I used them since they had a different crush height and I wanted to fine tune a compression ratio and I was very happy with them.
Old 12-16-2007, 10:22 PM
kringold's Avatar
ATA Welding Technology
Last wiki edit: How to rebuild an engine Last photo:
Another vote for Fel Pro.
Old 12-17-2007, 01:17 AM
I normally use the Fel Pros myself. I used the Mr. Gaskets Ultra seals on my last build with no problems and would use them again. What about copper?
Jordon
Old 12-17-2007, 04:30 AM
DoubleVision's Avatar
It`s rare I use Fel Pro head gaskets, I usually use GM head gaskets or Mr. Gasket, whatever I can find that has the correct height to get a good quench. Fel Pro is a excellant gasket and in the past when I used them on basic or high performance builds they worked fine. I Just about only use Victor Reinz Gaskets, these are made by Dana and the quality is outstanding.
The Mr. Gasket head gaskets are about the only thing they make I`ll use, the gaskets are excellant.
Old 12-17-2007, 04:44 AM
Last journal entry: PICTURE TEST
gaskets
I also use a bunch of fel-pro gaskets.
I buy kits from my warehouse that are all Corteco gaskets. I can tell you that I am just as impressed with there quality as the fel-pro stuff. I even have a set of the out-of-the box (non-race) head gaskets on a 12.1:1 406. That customer is a bit hard on engines. I got it back after about 20,000 miles of street driving and about 100 1/4 mile passes and there was zero head gasket isues. I put the same head gaskets back on it ( a new set, not the used ones) this time.
Keith
Old 12-17-2007, 04:11 PM
Jmark's Avatar
Yep, Fel Pro's here too.
Mark
Old 12-17-2007, 05:15 PM
I forgot about victor reinz...
WARNING Mr Gasket Fuel Filter Problems SilverFox2 Engine 11 09-08-2008 04:36 PM
Mr. Gasket Arcuden Engine 12 10-02-2007 04:27 PM
Percy xx carbon exhaust gasket material - passed my first (and second) stress tests lowROLLERchevy Engine 6 02-17-2007 09:29 PM
Help! Piece of Gasket Fell Into Intake... lead09 Engine 11 08-18-2006 08:07 AM
Changing pan gasket on 350 chevy rapsag Engine 16 08-04-2005 07:55 AM
