Gasket material? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-02-2004, 10:51 AM
New Member
Gasket material?
Is there a prefered gasket material that I should use when assembling my rearend?
It's a stock 1952 Cadillac rearend that I took apart and cleaned. Can I get away with some RTV, or do I need to cut a new gasket also?
Any ideas where I can get the right material?
Thanks
Old 07-02-2004, 11:49 AM
BOBCRMAN@aol.com's Avatar
If you want a paper gasket. Material is available in sheet goods from a good Auto parts store. Most just use RTV anymore.
