gasket material for accessories - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-14-2013, 01:33 PM
jims48's Avatar
Jim
I have spotlights on the front windshield pillars. Both the rubber gaskets are worn badly. I searched on the web for replacements and couldn't find any. I was wondering whether anyone knew of gasket material that would work and where to get it.
Name:	spotlight gasket.jpg
Old 04-14-2013, 01:41 PM
Faith - Respect - Trust
Any automotive supply store should have gasket material in whatever thickness you need. They would have different types of gasket material from paper to cork and have seen a synthetic type of material that does look like rubber. They are sold in various sizes of sheets and sold separately. You could use your existing gasket as a template to make a new one. If the old gasket is far gone, use the spotlight mounting bracket to make as a template for the gasket.
Hope this helps.
Ray
Old 04-14-2013, 03:18 PM
sedanbob's Avatar
Check for a local rubber supply house. One near me has a variety of thicknesses and densities. It can be trimmed with a utility knife, and holes punched easily with leather punches. I used 1/8" thick strips to replace the webbing between my chassis and body, with a dab of silicone under it to keep it in place as I mounted the body.
Old 04-15-2013, 09:35 AM
My local hardware store has a pretty good selection of rubber, foam and cork material all the way to two feet wide or so on rolls that you just cut off what you need. My boss cleaned out a cabinet at work and tossed out a bunch of stuff and in it was a nice roll of 2" wide rubber for stuff like that, I didn't let it get away.
Old 04-15-2013, 10:20 AM
cyclopsblown34's Avatar
Colorsanding painter
Check out any rubber supply or conveyor belt companies. We keep all different thicknesses in tan or black in Kansas City.
Old 04-15-2013, 11:06 AM
Irelands child's Avatar
For about two - three bucks +/-, go to Walmart or similar and buy a bike tube. I used one for the seals under my mirrors.
Irelands child
Old 04-15-2013, 12:22 PM
or you could just stop at a local body shop and see if they have an old ABS (black plastic) fender liner. Cuts, shapes and forms well and won't look like the photo you posted in a few years
Old 04-15-2013, 04:04 PM
jims48's Avatar
Jim
Thanks everyone for the replies. From the info you gave me, I will find something that should work.. I will post back what I find and use.
Best gasket material for intake manifold? Nite Life Engine 10 08-11-2010 06:32 PM
Supercharger Gasket Material? xxllmm4 Engine 4 02-03-2009 08:21 PM
Fuel Resistant Gasket Maker or Material? jhilb Engine 9 05-08-2008 05:01 PM
Gasket material oldred General Rodding Tech 6 11-05-2007 12:02 AM
Gasket material? 52Caddy Transmission - Rearend 1 07-02-2004 10:49 AM
