gasket or sealer? - Hot Rod Forum : Hotrodders Bulletin Board
View Poll Results: gasket or sealer?
gasket 2 6.06%
gasket and sealer 30 90.91%
sealer only 1 3.03%
Voters: 33. You may not vote on this poll
Old 05-01-2004, 02:39 AM
akm akm is offline
gasket or sealer?
i was at autozone a while back getting a waterpump for a buddy's car, and when he went to check out, the guy asked if we needed any sealant. i said no, you don't need that stuff, all you need is the gasket. he looked at me like i was a freaking ******* and said "oooooooookkkkkkkkk" then rolled his eyes.
i felt like back handing the old fart but just went about my business.
i was wondering what you use:
1. gasket only
2. gasket and sealer
3. sealer only
i never use sealer unless it is at the corners of an oil pan. never had a problem.
Old 05-01-2004, 08:36 AM
406chevelle's Avatar
One of these days...soon
For a water pump I have always used a thin film of sealant, give me peace of mind and helps hold the gasket in place when installing the pump, but I don't think it is necessary.
406chevelle
Old 05-01-2004, 10:31 AM
chev64lwbstpsd's Avatar
New Member
i use both
a thin film of sealant, keeps the gasket in place
.. :tip: get your finger wet (water) before smearing the sealant ..
will come right of in one swipe of a towel
Old 05-01-2004, 12:37 PM
I use yellow weather strip sealant and gasket.
Never had any leaks.
Old 05-01-2004, 01:03 PM
BstMech's Avatar
NYOFP4RJ3CHRIS
I generally use spray tack (sp?) or a real thin smear of sealant on paper gaskets.
Old 05-01-2004, 01:40 PM
Ghetto Jet's Avatar
current hot rod: CTS-V
Last journal entry: Lets Get Started With the Improvements
Indian Head Gasket Sealant + the gasket. Never leaks.
Mike
Old 05-01-2004, 01:54 PM
Frisco's Avatar
Glad To Be Here
Originally posted by chev64lwbstpsd
i use both
I do the same. Works great. Also makes gasket removal much easier.
Your tip is excellent and works.
Old 05-01-2004, 10:23 PM
Old 05-02-2004, 01:41 AM
Rick 5150 69's Avatar
Hy tack plus gasket no problems.
Old 05-02-2004, 10:39 PM
killerformula's Avatar
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
agreed, that guy's a tard.
Gasket and sealer.
K
Old 05-03-2004, 11:08 AM
k2mooch's Avatar
Except for a head gasket, or exhaust gasket, I'll use both on just about everything.
Carb to manifold, water pump, valve covers, thermostat, heck I even dab a little on the water neck before I slide the hose on. It helps out in a big way if you have a rusted, chipped, or scratched water neck.
MoocH
Old 05-03-2004, 12:01 PM
akm akm is offline
crap.
guess i'm the only one in the damn world that uses gasket only.
Old 05-03-2004, 09:26 PM
No, there's a bunch more out there that they just decided they use both, how many use sealant on carb/manifold, if so what? I don`t if I can get away with it, I just test it with berryman while its running.
Old 05-04-2004, 01:59 PM
bullheimer's Avatar
NEVER use credit cards!
used just black form a gasket silicon on the last water neck i did and it leaked! even waited a couple hours before adding the water. used a gasket with the black poo again and it worked
Old 05-04-2004, 08:00 PM
79 camaro 454's Avatar
yep
i always use the elastomer coated gaskets so sealer is already there ..ive never had a leak from a failed gasket yet..bit more pricey though.
