which gasket to use on a gen1 355 sbc - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-12-2011, 01:09 PM
bigjuice's Avatar
hi guys i'm new to all this .i have 1969 sbc 355 with flat top pistons, eye brows typed. motor was running but had bad valves. i got a set of bowtie phaseII 64cc 185 intake and a air gap rpm edelbrock 7501 intake. should be a stock crank but not sure. i got a new cam by the name of lunati 60103. adv dur is 268/276 and valve lift 489- 504. im putting it together as soon as i get the heads. my question is what type of gasket to get. their is so many part #s on felpro. i got a set of mr gasket # 7100 head gasket left. is that ok to use or go with felpro. do you think this is a good set up and how much horse i will get.i'm also using a 650 edelbrock carb
Old 03-12-2011, 02:33 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Welcome to the site, IIRC the gaskets should be fine, If you post this in the engine section someone else can help also not everyone checks the intro section.
Cole
Old 03-12-2011, 02:48 PM
bigjuice's Avatar
thank you. what you think about the set up with the cam and the heads
Old 03-12-2011, 03:39 PM
WDCreech's Avatar
Grumpy Old Goat Herder
That question also belongs in the engine section!
Old 03-12-2011, 04:11 PM
bullheimer's Avatar
NEVER use credit cards!
yeah, but gaskets schmaskets.
Old 03-12-2011, 07:42 PM
v8hed's Avatar
AK427
That head gasket looks to be a stock replacement gasket, so should work fine. Pretty much any head gasket would work just fine... they vary mostly by the compressed thickness to tune fine-tune CR and quench.
GEN2LT1/GEN1/Ford Powertrain System MOD ASEuro Engine 2 03-17-2010 04:20 PM
g body motor upgrade, gen1,lt, or ls? ol'wood75 Hotrodding Basics 13 04-17-2009 11:15 AM
gen1 sbc in 97 camaro mupton Engine 1 04-15-2007 04:37 PM
Bellhousing bolt pattern LS1 vs gen1 70bird Engine 1 12-12-2006 11:24 PM
1998 Gen1 350 w/64cc vortec heads underdog305 Engine 7 10-05-2006 07:50 PM
