Gaskets - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-28-2005, 10:34 PM
Gaskets
Hello,
I'm building a 454. I believe it was cast to be a 427 in 1969 but was cut to accept the larger crank, etc for the 1970 454 year. My problem is finding the correct head gaskets. I've tried calling summit for felpro and both times I've received what appears to be the wrong ones. They have sent both #1027 #1071-1. The problem is that the dia. of the holes in the gasket for what I think is the water chambers are much too small. This will cause the potential for higher temps. Does anybody actually know the correct felpro gasket # for this engine. It's a hi-perf block.
Old 11-28-2005, 11:33 PM
techinspector1's Avatar
Wiki Edits: 326
There's nothing wrong with either of the gaskets they sent you. The water passage holes in the gaskets are not necessarily the same size as the holes in the block or heads. The 1027 is a bore of 4.370" and is 0.039" compressed.
The 1071 is a bore of 4.380" and is 0.041 compressed.
Use either one.
Old 11-29-2005, 08:51 AM
gaskets
Thanks! will the 1071 work on this block with .030 bore?
Old 11-29-2005, 10:31 AM
Wiki Edits: 326
yes it will
copper exhaust gaskets......HELP!!!! trick66 Engine 11 12-10-2006 10:12 AM
Intake manifold temperature and gaskets club327 Engine 3 07-19-2005 12:22 AM
Intake gaskets MHenricks Engine 0 02-08-2003 06:26 AM
Intake Gaskets Malibu406 Engine 1 09-07-2002 09:44 PM
Head Gaskets HotRodS10 Engine 4 08-13-2002 04:30 PM
