Gaskets, Pumps, Thermostats, Plugs, Radiator - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-07-2005, 08:40 PM
tay tay is offline
New Member
Thanks to all who have provided advice so far. I have completed the build of a 383, and now am removing the accessories from the 350 and putting them on the 383 for install.
My questions so far:
1. What temperature thermostat would you recommend?
2. Would you reuse the water pump which worked fine before?
3. What spark plugs would you recommend?
4. Do you think I should send the radiator to a shop for "rebuilding", or would you recommend an aftermarket radiator?
5. Any problem reusing fuel pump (mechanical)?
The car is a 1980 Z28 with automatic and AC. It will be used for occasional cruising. I am excited to keep moving on this now that I have started. It seems that all I do is remove parts, clean, prep, paint, etc., and I'm loving every single minute of it!
Thanks again for the past and future help.
Tay
Old 07-07-2005, 08:47 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
answers
1 If you use a temp gage. You may want to omit using a thermostat until after break in. The motor will be tight and run hotter. Otherwise use a 180 deg therm.
2 Yes use your old water pump.
3 Use the spark plug recommended by the manufacturer for your particular head.
4 See how hot you run before worrying about the rad. Overheating can sometimes be cured by simply buying a better fan.
5 I would opt for the Holley high volume mechanical pump.
Old 07-08-2005, 06:23 AM
tay tay is offline
New Member
Heads are GM fastburn 194's
bracketeer,
Thanks for the info. The heads are GM fastburn 194's. I didn't ask the supplier the recommendations for these when I bought them. Live and learn, I guess. Any ideas from those who know these heads?
Thanks again,
Tay
Radiator Help Smoked Rubber Engine 6 04-20-2005 01:19 AM
Radiator questions RObs71Nova Engine 1 10-28-2004 05:18 AM
Rant: Bosch Plugs Cost me $300.00 Rolm Engine 7 07-22-2004 09:50 PM
radiator foaming? dbuff Engine 6 07-22-2004 04:02 PM
is this a usable radiator guba_unus Engine 4 07-16-2004 04:37 AM
