Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - gasser front axle
Old 10-17-2002, 05:32 AM
willys36@aol.com's Avatar
willys36@aol.com willys36@aol.com is offline
Wiki Edits: 21
Post
Another point I forgot - IF you use a stock style steering gear/parallel drag link (not cross steer), keep the drag link parallel with the springs. This will also minimize bump steer. If the drag link is at a different angle, the sprong and draglink will move in different arcs causing unwanted movement of the spindles.
