Gassy air but no fuel through line - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-10-2010, 08:06 PM
fourspeedwagon's Avatar
6 reps of 12oz curls
Last journal entry: 65 SS Project
Car is my 64 chevelle wagon. Been sitting a while. I used my air compressor to blow into the gas tank. Up at the fuel pump, all I get is air that smells like gas but no gas. I pulled the pickup out of the tank to see if it rotted off, but no. It has almost 5 gallons of fuel in the tank and I have not seen any signs of leakage. How can the air come, but not the fuel? Thanks in advance- Greg
Old 09-10-2010, 08:18 PM
DoubleVision's Avatar
If there`s a hole in the line all you`ll get is air but no fuel. But also if the tank has a purge line or a vent you can pump all the air you want in the tank and it won`t make any difference as that`s where your air is escaping.
I`m not sure what year purge lines were added or how they vented the tanks in those days but usually a tip valve was used in case the vehicle tipped over so it wouldn`t leak fuel.
Old 09-10-2010, 08:40 PM
adantessr's Avatar
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
Sounds like the vent line is at the fuel pump instead of the fuel line but then you would have fuel coming out of the other line onto the ground . Hmmmm . Just thinkin'
Old 09-10-2010, 09:00 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
The 64 chevelle gas tank is vented.
Rich
Old 09-10-2010, 09:34 PM
adantessr's Avatar
'23 T-Bucket Pickup
Wiki Edits: 3
Originally Posted by richard stewart 3rd
Hi,
Rich
Yeah , I know . That's why it doesn't make sense . It sounds like coming out of the vent line , but like you said .....Can't be. Did right by checking the pickup tube . I don't understand how it can happen if everything is up to snuff inside of the tank .
Old 09-11-2010, 07:42 PM
I think I see what Rich is saying- I won't be able to build any pressure to push the fuel forward because the tank has a vent, right?
Here's a snap of it from when the engine just was going in..
Name:	454 in the bay.JPG
Old 09-12-2010, 01:50 PM
Hi,
That's correct.
On some 64s along the line from tank to pump, there is a rubber hose you might want to check that out. Did any gas drip when you disconnected the line from the pump? have you tried pumping air from the pump end of the line to the tank?
Rich
Old 09-12-2010, 02:26 PM
T-bucket23's Avatar
Wiki Edits: 26
The rubber hose can dry out and suck air instead of fuel
Chet
Holley fuel pump, return line or not to return line??? JD's camaro Engine 1 07-16-2010 06:17 PM
Braided fuel line.... muscarmad Engine 14 06-21-2010 10:00 PM
Fuel Line Plumbing Help leejoy Engine 0 02-16-2007 10:21 PM
Revamping Fuel System topdogger Engine 6 12-29-2006 01:13 AM
Aluminum fuel line vs. rubber near engine McDeuce Engine 1 02-16-2004 07:39 PM
