gastank /fuel pump - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-11-2013, 04:31 PM
the youngone
Last journal entry: progressthe
gastank /fuel pump
hi another question
im boulding also an rvs gastank .. but i dont know what fuel pump is the best for my aplication.. its about the 305 carb bloc( think edelbrock 600 carb i have no mechanical fuelpump there is a hole for it but i want to use an electric pump and maybe pressure regulator .. i would like to start the fuel pump with an swich
so wath is the best for me and how much psi do i need
thankyou all
Old 02-11-2013, 04:32 PM
the youngone
Uploaded with ImageShack.us
Old 02-11-2013, 05:09 PM
delawarebill's Avatar
fuel pump
pressure on that carb needs to be in the 4 psi area.. 6# and u need a regulator. check your local auto part store and for one on the shelf.. i'm using a pep boys (u most likely don't have them) and it puts out just over 4# and no reg.
Old 02-11-2013, 05:44 PM
painted jester's Avatar
TAKE A KID TO A CAR SHOW
Last journal entry: Wifes 79 comeing together!
I agree with Bill But you must consider volume don't get a 4 LB. little pump for a 4 cylinder!
Jester
Old 02-11-2013, 10:29 PM
the youngone
Ok so better a. To large pump and regulate the pressuere down ? But what type of pump do i need. .. Am i using a retour line ? Or just 1 line
Old 02-12-2013, 06:46 AM
pump
u will only need a single fuel line, no return needed. if i read your post right u are running it in a RV ???? if so your not looking at hi volume. if looking at your local auto parts store there are many brand names.
Old 02-12-2013, 07:06 AM
the youngone
Its going in a van with my 305 250-275 hp. .
Old 02-12-2013, 09:47 AM
There are cheep electric pumps like the Mr. gasket for 4 cylinders I'm just saying don't use those pumps with a V8 they have very low volume!
Unless Delawarebill thinks they are good pumps for V8s
No disrespect but either you read my post wrong or I did yours Bill LOL
Jester
95 gmc jimmy fuel pump won't shut off/fuel pump relay garystrosnider Electrical 7 10-28-2010 07:10 AM
Fuel Pump Not Sending Gas To Carb Why?? Its Not Electric Fuel Pump???? zeeman19 Engine 7 02-13-2007 03:17 PM
Inline fuel pump vs. in tank fuel pump wheel-7 Engine 2 09-02-2006 06:57 AM
TPI 350 fuel pump *VERSUS* a Multiport 2.8L fuel pump boneyard Buick Engine 8 06-04-2006 11:56 PM
TPI 350 fuel pump *VERSUS* a Multiport 2.8L fuel pump boneyard Buick Engine 0 03-18-2006 09:40 PM
