gauge cluster help - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-20-2013, 03:13 PM
gauge cluster help
I am needing help my 1981 firebird gauge cluster the guy who built the car put them in the the console and after years of sitting they won't work I have started to work on it again I can't find where they hook up at to get the power to them just needing advice thanks
Old 03-20-2013, 07:50 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
Aftermarket gauges will need a common feed of 12 volt ignition and ground.
Oil pressure and water temperature will be wired to their respective senders on the engine. The fuel level will be wired to the fuel tank sender. The volt meter will simply read the ignition voltage.
The gauge lighting can be extended from the existing dash lighting.
vicrod
trans am gauge cluster dman0712 General Rodding Tech 4 07-05-2010 11:51 PM
90' gmc 1500 gauge cluster to 93' suburban cluster 90GMCVortec Electrical 0 02-16-2009 07:10 AM
cluster gauge trivera Electrical 4 05-21-2008 06:56 PM
What is this gauge cluster please anyone? imperial Interior 9 12-18-2005 11:33 AM
Oldsmobile 80's gauge cluster 87442lover Electrical 4 06-07-2004 12:32 AM
