Gauge grounds get hot - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-18-2008, 04:08 PM
RodFather's Avatar
I smell like a hotrod!
Last journal entry: windshield
I have a fiberglass car, and I just finished wiring it. I grounded the gauges, and when I went to start the car the ground wires got super hot. I'm using mechanical gauges and the same gauge wire that the harness has. I show that I'm getting a good ground when I use the meter. I also do not see any positive wire touching the gauges (thought a positive and negative were touching).
Suggestions?
Old 05-18-2008, 04:18 PM
How many gauges are you running through the one ground wire and what gauge is it. If you are running mechanical gauges what aer you grounding with this wire just the lights?
Mike
Old 05-18-2008, 08:55 PM
RodFather's Avatar
one ground lead for every two gauges..14 gauge wire. I added a couple ground straps to the car, and it doesn't get hot now.
Old 05-21-2008, 07:38 AM
re
Something else is grounding through your gauge ground, probably through the lighting circuit. Disconnect the ground and see what else does not work anymore
Old 05-21-2008, 04:53 PM
T-bucket23's Avatar
Wiki Edits: 26
Exactly, these are the things that car fires are made of
hot rod Fabrication Denton Md frdsuperduty Introduce Yourself 4 04-14-2008 08:11 AM
gas gauge trouble cutsupreme Electrical 4 01-25-2008 09:40 AM
2 new forums: Hot Rod Art and Off-Topic Jon Hotrodders' Lounge 2 09-23-2005 03:50 PM
New Gauge Wiring Chadman Electrical 1 04-08-2003 01:25 PM
