gauges - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-04-2011, 03:26 PM
55chevypanel's Avatar
gauges
I am building a 55 chevy panel truck . I am wanting to use the original gauges because they are in great shape , but I am going to be running a carbed 5.3L . Will this work or are my hopes of a stock dash gone .
Old 03-04-2011, 03:30 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
I am not sure about the gauges but someone will i am sure. I really like your avatar "SHOGUN" the badest mofolo down around this town.
Cole
Old 03-04-2011, 03:37 PM
Cole
thanks
SHO NUFF !!
Old 03-04-2011, 03:46 PM
eloc431962's Avatar
Wiki Edits: 37
I was thinking you should be able to get aftermarket/custom gauges that look stock but work with a newer set-up. Did you try google ?
Cole
Old 03-04-2011, 03:54 PM
tried google -- its an all in one type gauge so they make a plate to mount round gauges but nothing I found that looks like the old but works as new
Old 03-04-2011, 03:59 PM
ogre's Avatar
the 'Duracell Project'
check out the 55-59 chevy truck thread a lot of us over there.
i used my stock gauges. i did take them apart clean every thing up, new bulbs and crinkle painted the face.
new face plate is $10 from brothers. i used my old trim bezel.
i would not use the amp gauge, too much going thru there for the old gauge.
i did retrofit a volt gauge in the amp gauge and kept the stock look and needle.
i need to write that one up, but in a nutshell:
remove amp gauge
make volt meter work
cut off old needle
jb weld old needle on new gauge
Old 03-04-2011, 04:01 PM
ogre's Avatar
and post some pics over in the 55-59 thread
i love panels...
Old 03-04-2011, 04:04 PM
ogre's Avatar
and use your stock 55 temp sender.
your oil press gauge will be pegged cold and almost pegged warm
Old 03-04-2011, 04:11 PM
remove amp gauge
cut off old needle
Thats great news !- thanks for the info on the amp and temp and pressure too . I posted some a while back in that thread , but thought this topic was better suited for over here .
ill post em again cuase I like to show her off lol
gauges yragat Electrical 2 09-27-2007 04:15 PM
Gauges Alyson Hotrodders' Lounge 5 09-10-2006 08:27 PM
Gauges came to pass Interior 4 06-27-2006 05:11 AM
gauges liftedbowtie Interior 4 09-17-2004 04:02 PM
gauges fordred1 Introduce Yourself 0 09-02-2004 11:59 PM
