gauges go nuts - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-08-2009, 12:15 AM
gauges go nuts
Howdy.. I have a gauge problem that just recently showed up...
When I start my car ,the gauges all read strangely...some high some low.
When I turn on the headlights, they all peg!! Put on a turn signal ..the speed-o pulsates! The battery and alternator check out fine.
The car is a 3 year old '31 model A coupe-rod 350-350..with a 70's GM tilt column,Autometer gauges, single wire alternator and Painless harness. This thing is driving me nuts!! Can anybody help??
thanks...uncle dave
Old 02-08-2009, 12:30 AM
First thing I would check with a VOM is make sure you haven't lost a ground on the body or to the gauges.
Have you checked to make sure you have a good ground for the gauges. Sounds like they may all be grounded to one spot and your not getting a good ground. I had a similar problem on a stock blazer, replaced a bad ground wire and it went away.
Old 02-08-2009, 06:15 AM
da34guy's Avatar
Bad Ground ---Fer Sure
Rocker Arm Adjusting Nuts Problems - Help Me Diagnose leejoy Engine 8 11-26-2008 07:14 AM
Amazing Discovery about Ford F1 Gauges. lakota Hotrodding Basics 6 12-19-2007 01:44 AM
VDO Gauges gbowne1 Electrical 5 08-02-2006 10:14 PM
Custom gauges in 70 chevelle lumberjacknooj Interior 5 05-22-2006 11:17 PM
digital gauges mmartin1872 Electrical 6 01-06-2005 12:58 PM
