gbpack 31 coup (fill in roof) - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-18-2006, 10:07 AM
Hi
I Have A 31 Ford Coup And I Want To Fill In The Roof.do They Make A Filler Panal To Do This.if Not What Car Roof Matches Up The Best.
Thanks Gbpack
Old 01-18-2006, 10:11 AM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Roof panels off of old station wagons and vans work good for this. The ones with the ribs in them make for a neat look. I just used some sheet metal for mine and put just a little crown in it by working it a little over a empty oxygen bottle. Thats it in my Avatar.
1931 steve's Avatar
Last wiki edit: How to rebuild an engine Last photo:
Wiki Edits: 4
I have a 1931 sedan that I will be filling the top on, I haven't been able to find a pre made piece, I have did some research and found that the lid off a Chevy astro van will fit with some mods, also lids from station wagons will work. basically anything with the right length and width.
Steve
Old 01-18-2006, 10:39 AM
I filled in the roof on a 36 coupe. I used a roof from a 80 chevy monza hatch back. It was a perfect match for the shape of the 36 roof. It might work on your 31.
Bob
Old 01-18-2006, 11:41 AM
31 coupe roof
I have a friend who put an s-10 chevy roof in a 33 chevy coupe...........fit very nicely1
give it a look see, I believe it was a crew cab type
Old 01-19-2006, 01:31 PM
great ideas
thanks every one i have alot of info now on what to look for.
talk to ya later
gbpack
Old 01-19-2006, 03:35 PM
Shabby chic sheet metalshaper
The likelyhood of getting the right curves front to back and side to side in a donor panel is not high, but you can make up for a lack of shape (surface area) by stretching after you have welded the panel in. If the panel has too much shape you can shrink it down. A lot of work either way.
Reading the panel and deciding what it needs is a little tricky. A perfect panel with just the right amount of surface area might look like a panel with too much shape after welding, when in fact it needs stretching at the weld, not shrinking overall. Templates fore and aft, side to side will help a lot.
If you post pictures once you get started you'll get plenty of advice.
John
31 ford coupe solid roof markh55 Body - Exterior 8 04-02-2013 12:47 AM
31 model A pickup roof ? cruisecarl Body - Exterior 8 03-30-2005 06:00 AM
roof for 31 5 window dcurhotrod Body - Exterior 7 04-28-2003 02:43 AM
How to fill in 33 Chevy Sedan roof Dean293 Body - Exterior 3 02-15-2003 06:18 AM
fill roof in 34 chev duckman Body - Exterior 6 03-22-2002 08:35 AM
