Start a tech article on any subject...
...hundreds of hotrodders help build it into a comprehensive resource.
Fresh wiki articles that you can add to: Air suspension on a front solid axle, Basic stuff for newbies, Building a new shop, Ceramic insulation, Electric fuel pump mount, Engine and transmission mounts, Freeing a stuck engine, Gasser, How to check driveline angle, How to make a vacuum power brake bleeder, How to safely cut steel with a torch, Improving fuel economy, Narrowing a rearend, Patching a body panel, Quick-disconnect rear mount battery, Reducing vehicle weight, Stereo installation, Stripping paint, Valve spring setup, and many more...
Or, start a new article.
Hotrodders Bulletin Board > Tech Help > Engine
  #16
Old 10-29-2002, 06:32 AM
engineguy engineguy is offline
SAE Member, ASE Master Cert.
Post re: gear drive
Yup, I think that IF I was hell-bent on using a gear drive, I would use a two gear set-up with helical cut gears and use a reverse rotation cam. (The idler gear looks like a good place for some additional slack to show up.) Still going to have that problem with harmonics being transfered through the valve train and distributor, tho.
[ October 29, 2002: Message edited by: engineguy ]</p>
Old 10-30-2002, 09:04 AM
bullheimer's Avatar
bullheimer bullheimer is offline
<-rolling tribute to our dead
Post re: gear drive
i gotta Erson drive from Super Shops back in 95 and had no probs. tore it apart last year and no signs of wear. put it back on and no probs. it has a single idler gear tho, and some think the dual idler gear set ups lose their accuracy after awhile--couldnt tell you. the bad vibe thy. sounds logical. my mill never turned over 6300 with the isky cam and only spins to somewhere in the 5's now tho. i've also heard they take more h.p. to drive than chains so if i was racin probly wouldnt use it. i just got it for the sound effects/
Old 10-30-2002, 01:28 PM
drgnwgn289's Avatar
drgnwgn289 drgnwgn289 is offline
Post re: gear drive
You want a good gear drive....get a Studebaker motor!!!
Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
