Gear Drive?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-11-2003, 11:14 PM
horvath's Avatar
Acoustic Rock ... for real.
Last journal entry: About Fusible Links
Post Gear Drive??
I just got me a '54 Chevy pickup ... it's in great shape and was put together nicely - 350 w/gear drive, Edelbroke manifold, Q-jet carb, electric choke and pull-off, headers, 350 turbo trans, 12 bolt Chevy rear, gas tank moved under the bed ... I love this truck!
But -- I haven't got a clue what a gear drive is all about!
:o
Can someone explain why I might not want to swap it out? Personally, I like to listen to my engine while I'm driving, and tho' my mechanic says this is the quietest gear drive he's ever heard, the "whining" isn't to my liking.
I've never heard of a gear drive before. What's the diff?
Thanks.
Alan Horvath
<a href="http://AlanHorvath.com/" target="_blank">http://AlanHorvath.com/</a>
Old 02-11-2003, 11:21 PM
Cool
A gear drive replaces the timing chain and sprokets at the front of the engine. It is usually used when a camshaft can utilize a fair amount of valve spring pressure as there is no way for it to stretch and therefore retard the valve events. Using this setup to drive a mild street cam is a personal choice. Some guys just like them and are willing to put up with the minor gear whine. They are quite a bit more costly than the usual chain and sprocket arrangement, so that may figure in your decision.
Old 02-12-2003, 12:52 AM
horvath's Avatar
Post
Thanks, Slider
So ... would it be unwise for me to lose the gear drive and go with a timing chain, etc?
Would the engine or mild cam perform any differently without the gear drive?
Old 02-12-2003, 01:34 AM
Honorary Redneck
Post
as slider said, it's a personal choice;
I would stick with the gear drive as it doesn't stretch and will outlast any timing chain and will withstand more torque (although typically they don't like to be revved as high e.g. &gt; 6000rpm, but I doubt you'll be re-building your truck to rev high anyway).
However, you could sell the gear drive as second hand and probably get enough to buy a brand new high spec timing chain.
Either way it won't change the performance or running of your engine...
Old 02-12-2003, 02:13 AM
horvath's Avatar
Post
Thanks, AndyBird
This bulletin board is the BEST!!!
Old 02-12-2003, 07:27 AM
willys36@aol.com's Avatar
Wiki Edits: 21
Post
Chevy straight 6s have been using gear drives for nigh-on 80 years and haven't done too shabby!
Old 02-12-2003, 08:01 AM
Post
If you dont like the whine, change the gear drive to a chain, sell the gear drive. With your performance level its not going to make a difference.
Old 02-12-2003, 12:14 PM
horvath's Avatar
Post
Thanks again, guys.
If I had a straight-6 I'd probably keep the gear drive ... but this engine roars pretty sweet and I want to listen!
So ... how do you normally go about selling something like a used gear drive? Ebay? It's only got 19,000 miles on it, too.
Old 02-12-2003, 01:07 PM
Post
what kind of gear drive is it? Pete jackson? Edelbrock? dynagear? Is it a noisy or quiet one? {There are 2 different styles} let me know.
Old 02-12-2003, 07:46 PM
horvath's Avatar
Post
It's the "quietest gear drive" my mechanic has ever heard.
I won't know what kind it is until we swap it out ... I'm in no rush about it -- probably get to it by Summer -- but I'll keep you posted.
Thanks, bro'.
