Gear drive Q - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-02-2007, 11:04 PM
bigalow's Avatar
Gear drive Q
I Put a Pete Jackson gear Drive in my 440 Dodge when I built it. Just like the way it sounds. I have a few bucks in the motor. Roller cam, decent rods, Crank, Al heads.(don't want bad things to happen with valvetrain!
I drive the car on the highway alot. 3:23 rearend. This guy I met told me the gear drive won't hold up and is not designed for constant cruising. Is this true and should I cange to a chain? Thanks
Old 11-02-2007, 11:14 PM
bigalow's Avatar
I will search first next time. Any new info on longevity would be cool. Do I need to check the button?
Old 11-03-2007, 09:13 AM
re: Gear drive Q
I had always been told that with a chain drive, the stretch in the chain helps absorb some of the shock when a cylinder fires, a gear drive however would transmit that shock straight to the cam and valve train.
Old 11-03-2007, 12:43 PM
WDCreech's Avatar
Grumpy Old Goat Herder
In the late sixties and early seventies, I ran a Milodon gear drive on big (for that time) hydraulic cams. It worked well on a couple different engines. Then I switched to a solid roller, with only a .540 lift, in a new build. Wore the valve springs out in about 25 to 30 passes. I thought that I might have gotten a bad set of roller springs, so I put a new set in. Same senario! Bought new springs an a Rollmaster timing set and it solved my problem. It seems that a gear drive will transfer harmonics to the valve train unless there is something to dampen them like a blower belt or maybe hydraulic lifters. I now run a belt drive set up in my big engine, but if I build a back-up, it will more than likely have a Rollmaster chain.
ID:	25253   Click image for larger version
ID:	25254   Click image for larger version
Old 11-03-2007, 04:23 PM
bigalow's Avatar
I have had various problems with the valvetrain and have to fiddle with it. I thought it was just the roller set-up. Rocker arm adj nuts for one. I sure would miss the whine of the gear drive at 70MPH.
Old 11-03-2007, 08:23 PM
WDCreech's Avatar
Also, I've read that the two idler gear set isn't very dependable at rpm. Apparently, they can kick one idler and really mess up an engine.
Old 11-03-2007, 08:25 PM
King of my Man-cave.
I have seen 2 gear drive sets fail. Break. I have yet to see a performance chain drive timing set fail in a V-8.
tom
Old 11-03-2007, 09:36 PM
Registered Loser...I mean User
Jesal
What about those Jesel timing belt setups? I know they are ment for oval racing so perhaps have a fairly frequent belt replacement requirement apparently they are quite dependable. Anyone have experience with them as I'm looking at trying them out?
TH 350 Speedo Drive Gear Mr Bob Transmission - Rearend 11 01-12-2007 05:37 AM
GEAR DRIVE = DAMPER PROBLEM bullheimer Engine 5 07-06-2006 12:09 PM
stalling a Pete Jackson Gear Drive in a SPC tim gleason Engine 2 06-22-2006 07:54 PM
distributer drive gear oldred Engine 5 12-04-2005 07:26 AM
summit racing gear drive? cragars Engine 14 05-30-2004 02:30 AM
