Gear Drive vs Dual Timing chains - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-12-2011, 07:54 PM
What are your opinions about both? I'm hearing mixed about both!
Old 02-12-2011, 08:06 PM
bigdog7373's Avatar
Of course it's fast
Double roller is quieter and gives more power but doesnt last as long and stretches over time. Gear drive has a cool sound but you'll lose a tiny bit of power, more durable, doesnt alter timing like chain stretch.
Old 02-12-2011, 09:22 PM
lg1969's Avatar
Google "Tunnel Ram 406"
I used both Double Roller and Gear drive. The first 10-15years I was using double roller. The next 30 years I used gear drive and still using gear drive on my 406sbc. What bigdog 7373 is right. They sound great to me and I rarely adjust the timing.
Old 02-13-2011, 07:07 AM
BOBCRMAN@aol.com's Avatar
As i've said before. A gear drive is the worst thing you can do to a Chevrolet engine.
Gear drives transfer any crank harmonics to the valve train.
If you had ever seen the effects gear drives have on valve train parts in a running engine. You would never use another...
Old 02-13-2011, 09:29 PM
lg1969's Avatar
I found nothing worn just by using gear drive. I do not believe it at all. After using it for around 25 years. I was well known when going to criuse night for years in my 69 Chevelle. They heard me coming before they saw me.
Old 02-14-2011, 03:09 AM
bentwings's Avatar
bentwings
I just put 12,000 miles on my hotrod last year and 1500 the year before. Not only do I have a gear drive but I use only a crank hub instead of a balancer for the blower belt and accessory drive. Add to this aluminum roller rocker arms and ball ended heat treated push rods with guide plates. It goes without saying I use a flat tappet hyd cam with performance lifters too. I forgot, I also use a high vol high pressure oil pump. All "wrong".
I adjusted the valve train at the beginning of the year and that was it. After I finalized the timing I never adjusted it again either. I checked it regularly however.
My Cummins diesel has a massive gear train for the cam and injector pump as well as other drives. I've got 250k on that motor and never have adjusted the valves. Checked but didn't need adjusting.
Old 02-14-2011, 07:35 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Be aware there are different types/styles of "gear drives". Some use a floating idler, some have pinned idlers on either side, some require the block to be machined to fit in some cases. Most fit under a stock size timing cover, but check all this beforehand, should you decide to use one.
But, IMO there's nothing to be gained by using a gear drive. In my experience, a good true roller timing set will last 50K miles-plus in your average street performance engine.
Old 02-14-2011, 06:58 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
You're gonna find people on both sides of the gear drive argument. I personally can't stand the sound of a gear drive. I performed a cam swap on a 350 of mine and decided to put in a gear drive just for the heck of it. As soon as i started the engine up for break in I couldn't stand the noise. I had the truck for three years after that and even though I never pulled it back out I couldn't stand the thing.
Old 02-15-2011, 12:41 AM
bentwings's Avatar
bentwings
I gotta admidt that the sound of the gear drive on the unblown motor was not like the sound of the blower at all. And I agree that it got old after a while. The blower now seems to cancel it and is much less grating. It actually is nice purr as you go down the road.
If the gears were helical and set up so the thrust was toward the block, you would have an ideal situation. Cam walk on roller cam would go way and you would have a quiet and bullet proof system.
The single gear systems like a Milodon are much quieter.
Old 02-15-2011, 01:29 AM
Blazin72's Avatar
Wiki Edits: 19
Can't argue with that one bit. A blower making boost at 5000+ rpm sounds pretty darn good and nothing like a gear drive.
Old 02-15-2011, 04:23 AM
bentwings's Avatar
bentwings
The 8mm belt has a sound of it's own too compared to the 1/2 in pitch flat timing belt.
Old 02-15-2011, 12:00 PM
Blazin72's Avatar
Wiki Edits: 19
Never heard that. The only thing I can reference for sound is the gear whine from the little 142 I had. It was definitely different than a gear drive and it sounded great at high RPM.
Old 02-15-2011, 02:31 PM
ericnova72's Avatar
More for Less Racer
You won't find anyone serious about racing (Hobby or Professional) using a floating idler gear drive, like the Pete Jackson.
If they are using a gear drive it is a single fixed idler type.
Most use a good chain set-up or step up to a Belt drive.
Old 02-15-2011, 02:46 PM
lg1969's Avatar
http://www.hotrodders.com/gallery/sh...cat/500/page/3
Had it more then 20 years
BTW: This one is from Edlebrock
Old 02-15-2011, 07:19 PM
Von MoPar's Avatar
B&M gear drive
installed a B&M gear drive on a SBC 1986 ish, it's very noisy as the idler is mounted to the aluminum timing cover.........
oh-well some people like it others don't
noisey timing gear drive needs grinding crankshaft3rd Engine 3 01-21-2011 09:19 AM
gear drive timing set sexypizzaman Engine 4 10-18-2009 10:21 PM
timing chains, gear drives, and covers 95dime Engine 9 04-22-2009 02:03 PM
Gear-Drive Timing Set vs. Chain-Drive Timing Set nightrain_rod Engine 8 12-25-2003 04:36 PM
Swapping Gear Drive Out for Timing Chain or Belt Drive - Need Suggestions horvath Engine 4 05-24-2003 09:47 PM
