GEAR DRIVES....First time user - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-03-2008, 08:45 PM
I just completed building a motor for my vette and it's still on the engine stand. I installed a "ProComp" Gear Drive and noticed that if I rotate the engine the opposite way, there is quite alot of backlash(play) between the crank and cam. YEAH, I realize that the engine will only be rotating one direction, howver, timing chains have virtually no backlash. Is this normal?
Paul
Old 08-04-2008, 05:31 AM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
Any gear setup has some backlash. I'm sure your gear drive was designed with that in mind. Like you said, the engine only rotates one direction. Can you masure how much backlash you actually have?
Old 08-04-2008, 06:38 AM
BOBCRMAN@aol.com's Avatar
Also, gear drives transfer any harmonics or vibrations from the lower end directly to the cam/valve train. Not a good situation. A good double roller chain is a much better choice.
Old 08-04-2008, 12:17 PM
Double_v23's Avatar
Horsepower Enthusiast
Last journal entry: Finished BMOD001FH
I noticed the same thing and have been running mine for a few thousand miles with no problems just make sure you took the time and did it right and it will last for a long time. It will probably last longer than your ability to stand all that racket it makes.
How do I remove the timing chain on a 350? piniongear Engine 9 09-20-2010 09:39 PM
first time user of damper installation tool bullheimer Engine 3 08-28-2005 09:14 PM
gear drive or timeing chain camino_man Engine 41 10-18-2004 03:13 PM
CAT, gear drives brainsboy Engine 9 08-17-2004 08:28 PM
Proform Gear Drives 48 Burb Engine 7 05-26-2004 10:27 AM
