gear drives problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-13-2011, 06:45 AM
Good morning, I have a 29 ford 2door sedan ( true steel ). I just bought a set of gear drives from summit that looked like they were half installed before. Summit was great in swapping them, however, there were none available in stock to replace them. I think there's a bad run on them n they pulled them .
Anybody else here of this ???
notakit
Old 08-13-2011, 08:21 AM
What was the brand name?
Most of us wouldnt use a gear drive anyway, not a good setup, too much harmonics that cause issues with cam and timing.
Old 08-13-2011, 10:53 AM
gear drives problem
The brand was from summit racing. when they checked for an instock replacement. none were available. they did find an edelbrock set that they over-nighted to me. I have used them in the past with no issues, however, if they are machined too tight they will wipe your cam quick .
Gear Drives chevyIIdie4 Engine 32 10-30-2005 02:36 PM
Sound clips of gear drives? Vids of cars w/ gear drives? Magnum Rockwilder Engine 12 08-14-2005 06:14 PM
CAT, gear drives brainsboy Engine 9 08-17-2004 08:28 PM
Proform Gear Drives 48 Burb Engine 7 05-26-2004 10:27 AM
Gear drives GearHead69 Engine 4 09-01-2003 11:01 AM
