Gear drives on roller cam - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-31-2005, 03:47 PM
I was wondering why all of the" gear drive" manufacturers for
cams say "Do not use with hydraulic roller cams". Does it create
a problem of some sort???
Old 01-31-2005, 04:44 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Welcome. Being new to the site, you need to be sure to read the "Read Me' posts at the beginning of each forum. The ones here for example recommend that you just post a general introduction here and post tech questions in the appropriate tech forum. This will give you the best chance for a good answer.
Old 02-01-2005, 10:00 AM
poncho62's Avatar
Wiki Edits: 5
moving to engine forum...
Ontario Rodders
Old 02-01-2005, 10:25 AM
BOBCRMAN@aol.com's Avatar
The upper gear won't clear the "thrust plate" on a stock hydraulic roller.
