gear i.d. - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-15-2005, 08:06 AM
msc66's Avatar
Last journal entry: pics
gear i.d.
Can anyone I.D. this 12 bolt ring and pinion for me.
Ring gear - 2 gm 3862689 13 43 4 69
pinion - 3862693
Thanks
Old 03-15-2005, 08:30 AM
(43/13=3.307692 or 3.31)
Old 03-15-2005, 07:13 PM
msc66's Avatar
Thanks! By these numbers, can you tell if this is actually the correct pinion and ring for each other? Just wondering.
Rear-end Setup opinions RObs71Nova Transmission - Rearend 6 03-11-2005 06:54 PM
Gear Swap. M&M CUSTOM Transmission - Rearend 3 06-26-2004 06:53 AM
Cam Gear and Crank Gear Alignment DTL504 Engine 15 05-06-2004 06:29 AM
Roller cam/distributor gear information Jmark Engine 0 12-29-2003 04:56 PM
More TECH On FORD Dist. Gear Failure KULTULZ Engine 8 03-18-2003 05:50 AM
