Gear or no Gear ... thats the Question ! - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-29-2006, 02:48 AM
"70" Cougar's Avatar
Meat-Head Extroidenaire
Well... the problem is the tranny and its shifting and or lack there of... It's a 91 Caprice 305 4speed auto.. i think its a 700r4.. but i don't know... the owner couldn't tell me for sure. I put it in drive.. and.. stays in first... go to manually shift it.. wen it goes into 3rd.. revs out... no gear.. back to 2nd.. and will only go into gear with lots of gas.. and then you have to slow down... it comes out of gear when you take your foot off throttle.. At all times its either in first of second... wont go into other gears.. i told him that as far as i know its due for a rebuild.. at least to some extent.. the fluid is fairly clean not burnt.. aswell its level is where it should be! If you could tell me any more with what ive told you than thanks...
thanks again
bill...
p.s.
i feel soo weird asking questions for ... chevy.... (shakes with the willies)
lol jk
Old 07-29-2006, 05:46 PM
66ImpSS396's Avatar
It's been fun
Gear or no gear
You should be able to ID the transmission from reading this thread.
Transmission ID
Sorry I can't help with the problem all i know about transmissions is they work on the FM Principle
power steering gear box question novadan Suspension - Brakes - Steering 2 05-25-2006 01:32 AM
7 hours, 33 phone calls, &30 pages of Threads later... Rearend? Tranny? Need Guidance 68ChevelleFromHell Suspension - Brakes - Steering 19 01-13-2006 01:01 PM
first post-hello-timing gear question rsrogers Introduce Yourself 2 01-20-2005 12:50 AM
Camaro 10-bolt 8.2 upgrade - gear question EricTopless68 Camaro Transmission - Rearend 0 02-23-2004 09:10 PM
hi, i have a rearend gear question Thuggishruggish3000 Transmission - Rearend 2 08-10-2003 12:55 PM
