Gear oil? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-13-2007, 11:22 AM
Gear oil?
This should be easy for you guys. I have a 1957 Chevy 10bolt rearend. I bought 2 quarts of Royal Purple and 1 quart of Lucas Diff. I'm pretty sure The rearend it's self will hold about 2 quarts. Should I put 1 and 1/2 qrt of royal and 1/2qrt of Lucas or would that be to much. Thanks Brian
Old 03-13-2007, 11:53 AM
Why not just remove the fill plug and fill till it's at the bottom of the hole?
Old 03-13-2007, 12:00 PM
Well I know that but I was wondering how much Lucas diff oil to use. If any at all. I hear Mechanic's swear by it. Literally "Lucas is the ch!t"
Old 03-13-2007, 04:12 PM
Why do you have 2 kinds ?? Is the Lucas an "oil treatment" ?? if it is, then read the bottle and go by their recommendations. If it's just gear oil...just fill her up
Old 03-13-2007, 07:01 PM
You may want to rethink using the Lucus stuff, Check this site http://www.bobistheoilguy.com/images/lucas/lucas.htm That article along with the guy on this board that used the engine oil additive in his Honda and it killed it in something like 30 miles. Personally I would stay away from anything Lucus.
Jordon
Old 03-13-2007, 08:24 PM
Why not just the GM lube that millions have used for years and years. I've never had a wear problem using it
Old 03-14-2007, 06:31 AM
302 Z28's Avatar
Do not use the Lucas stuff, the Royal Purple gear oil has everything you need already in it.
I advised a neighbor to use a Lucas product and it cost him $1500 to get the damage repaired on his motor home .
Update: I had not seen the link to Bob's website until I read this thread. I had advised my neighbor on a minor power steering leak on his motor home. This system uses a power steering system in conjunction with his brakes. I said there are products that are designed to stop minor leaks and I mentioned Lucas power steering additive. He tried it and few days later had major problems with his power steering and brakes. The additive caused foaming and totally messed the entire system up. It took a complete flush of the power steering and brake system to correct the problem. He called Lucas to inquire about the problem and they acted like it was the first time they had heard of it and were very un-apologetic.
The best advice you can have is use a quality lubrication product and stay away from any whiz bang additives.
Vince
Old 03-14-2007, 06:56 AM
Well I want to thank everyone for their knowledge on this topic. I also want to thank you for preventing future damage. That was a pretty good sight about the Lucas additives.
So I guess since I already bought the Royal purple I'll just use that and leave out the Lucas gear additive.
The reason I wanted to use Royal Purple is (don't laugh now) I saw Horse Power T.V. where they just switched out the motor oil,gear/diff oil,and Tranny fluid ( I think they did the tranny anyway's) with Royal purple and they got an 8 h.p. gain to the rear wheels. So I figured it can't hurt.
So again thanks for the help guys. I just became a member a few days ago and with in these few days you have definitely made me a loyal member. Thanks Brian
Old 03-14-2007, 07:03 AM
Oh I guess I should say I've always been against the additives. I always thought they were a waste of money. But when Lucas has that little display of the gears and you see the oil climb. I figured that had to work. I guess if I could spin those gears fast enough (like in the rearend of an axle) I could get the same foaming action. Lucas put's that there knowing there is no way a person could spin it that fast.
Like I said I really appreciate the help
Old 03-14-2007, 10:56 AM
Let me give you a tip....Don't believe EVERYTHING you see on T.V....or read in a magazine..LOL
Old 03-14-2007, 11:00 AM
302 Z28's Avatar
To refine that statement a little....be very suspicious of anything you see in a magazine or on TV. Also be suspicious of any sports figure (drag or NASCAR) that spouts loudly about how great their sponsors product is.
Vince
Old 03-14-2007, 12:13 PM
Irelands child's Avatar
Vince
...and Carroll Shelby is the biggest 'prostitute' padding his bank account by a selling to a company to use his name.
Irelands child
Old 03-15-2007, 06:41 AM
Yeah I kinda know that If someone were paying me big bucks yeah I would say they are the best. (just as long as they aren't the worst) And I've see the horse power increases in several different places........oh yeah but it was on a T.V. and in a magazine
Oh well I didn't buy the Royal Purple to add h.p. but for the reduction of friction. Where there is less friction (other than tires ) the better. Less wear and tear,less heat,more performance capability,etc.etc.
And I think I'm not going to use the Lucas oil. So there is $10.00 down the drain(for the green people not really down the drain......but then again I bet there are'nt any of them on here lol)
Old 03-16-2007, 05:46 PM
71 c-10's Avatar
just a kid and his truck
wow that kinda surprised me! I just re-did my rear and have about 100 miles on it, I filled it up with lucas gear oil 80-90, not aditive, and then the GM friction modifier for the posi, do you all think this is a problem and should I change it out to something else?
Old 03-17-2007, 03:22 PM
runn141's Avatar
i used a 1/2 quart of lucas additive in the rear diff. on my 4x4 truck, i havent had no problem with it its an open diff. and seems to work a little better in traction. ive never used it in a motor or automatic tranny though, im kinda afraid to.
89 chevy 1/2 ton 5-speed truck gear oil??? tiresmoke55 Transmission - Rearend 12 09-12-2006 10:46 PM
Excessive oil under valve covers in SBC? TVR383 Engine 13 11-21-2005 12:48 AM
distributor gear / oil pump rod issue?? bskaggs Engine 8 06-11-2004 08:02 PM
distributor gear / oil pump wear ?? help bskaggs Engine 9 05-04-2004 09:55 AM
which gear oil to use? darom Transmission - Rearend 4 02-12-2004 12:45 AM
