Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Which gear oil?
Thread: Which gear oil?
Old 06-24-2011, 12:44 PM
Madmax305's Avatar
Madmax305 Madmax305 is offline
Which gear oil?
I want to change the gear oil out of my 67 El Camino, it has a GM 12 bolt with posi and 4.10 gears. What do you recommend? I have read that you should not use synthetic gear oil for this. How much oil will it take and should I use an additive for the posi unit?
Also, what oil weight will be best?
