Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Which gear oil?
Thread: Which gear oil?
Old 06-25-2011, 06:43 AM
Ohio Hab Ohio Hab is offline
1984 C-10 383 SBC
I use Lucas Gear Lube 80-90W , for the posi unit if the unit is an Eaton use the G.M. additive from your local dealer. The GM additive is recommened by Eaton, and as stated in an previous post Eaton does not recommend synthetic oil. Rear axle assembly should take 2 1/4 quarts if totally drained.
