Which gear oil? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-24-2011, 12:44 PM
Madmax305's Avatar
Which gear oil?
I want to change the gear oil out of my 67 El Camino, it has a GM 12 bolt with posi and 4.10 gears. What do you recommend? I have read that you should not use synthetic gear oil for this. How much oil will it take and should I use an additive for the posi unit?
Also, what oil weight will be best?
Old 06-24-2011, 01:45 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi
75w90 name brand gear oil. some come with the clutch additive already in it, if not the dealer ship has it. As for synthetic Eaton says not to use it, to slick for the clutches to work properly
Rich
PS I can't remember how much it holds, but I think it about 2qts. I just put the additive in then fill it till it starts oozing out.
Old 06-25-2011, 05:43 AM
1984 C-10 383 SBC
I use Lucas Gear Lube 80-90W , for the posi unit if the unit is an Eaton use the G.M. additive from your local dealer. The GM additive is recommened by Eaton, and as stated in an previous post Eaton does not recommend synthetic oil. Rear axle assembly should take 2 1/4 quarts if totally drained.
Old 06-26-2011, 09:26 AM
Madmax305's Avatar
Thanks for the info guys...
700R4 2nd gear 4th gear bind up? zutaten_zucker1 Transmission - Rearend 1 02-25-2011 06:24 PM
How to install gear to gear timing SthrnStyle3 Engine 5 08-04-2009 10:45 AM
No reverse gear and slippage in Drive 2nd gear. jadejoky28 Transmission - Rearend 14 04-09-2009 11:49 AM
700R4 2nd gear start/4th gear bind up? myclone1 Transmission - Rearend 3 04-19-2005 02:51 PM
Rear gear choice, Gear to Tow icegnome Transmission - Rearend 3 12-03-2002 07:17 AM
