Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Gear Oil in NP205 behind a T-350?
Old 03-19-2013, 06:34 PM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
THE 205 T-case uses regular gear oil
If you have a proper adapter, there should be a seal in there that separates the trans oil from the t-case oil
