gear oil recommendation - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-02-2013, 12:36 PM
defilade's Avatar
2012
what fluid should I use after initial ring and pinion break in and posi install, i have amsoil severe gear 75w 90 in there now but I read bad things about it on internet
Old 05-02-2013, 01:18 PM
big gear head's Avatar
High Performance Rear Ends
I used that same oil for 15 years in hundreds of rear ends that I built and none of them ever had any problems except two. One was a Borg Warner rear end in a '04 GTO with a cone type differential. Had to change it to Torco oil to make it quiet again. The other one was a '96 Impala SS with an Auburn differential, which is also a cone type. I had to put 2 bottles of GM oil additive in it to make it quiet.
The Following User Says Thank You to big gear head For This Useful Post:
defilade (05-04-2013)
Need cam recommendation after gear ratio upgrade American Muscle Hotrodding Basics 0 03-13-2012 05:03 AM
Need recommendation on gear ratio kieferrestoration Hotrodding Basics 9 04-10-2010 11:19 AM
Oil Change recommendation. Everett II Hotrodding Basics 8 07-19-2007 08:39 PM
Info on Synthetic oil & gear oil Kenny G Hotrodding Basics 6 06-29-2006 10:13 PM
Drag race oil pan recommendation The Vandal Engine 12 01-04-2004 12:54 PM
