gear oil type - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-15-2006, 05:18 PM
gear oil type
I have a 1986 8.8 mustang rear. i drained the oil out and changed the axles to 5 lug axles.do i use the 80/90 gear oil and what kind of additive? thanks
Old 02-15-2006, 06:04 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Yes use the 80w90 and if its a posi you need to add a bottle of friction modifier also.
Old 02-15-2006, 06:24 PM
302 Z28's Avatar
Or you can use Royal Purple Max Gear oil. It already has the friction modifier in it.
Vince
distributor gear / oil pump rod issue?? bskaggs Engine 8 06-11-2004 08:02 PM
distributor gear / oil pump wear ?? help bskaggs Engine 9 05-04-2004 09:55 AM
Capacity for rear end gear oil 71gtx Transmission - Rearend 1 12-03-2003 12:45 AM
Should I change my oil? 48Man Engine 2 01-29-2003 07:28 AM
ATF or Gear Oil???????? chevyelc81 Transmission - Rearend 18 01-06-2003 03:00 PM
