Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Gear pattern check
Old 06-06-2011, 12:46 PM
HalfOunce HalfOunce is offline
There should be some that are stamped for the gear ratio but the pinion depth should be engraved ie hand written with an engraver. Most reputable companies do this. other wise you will have one heck of a time trying to guess what they had it set as to lap the gears at the factory. Anyway... It looks to me like the pinion needs a shim to set it back closer to the ring gear. hope ya have a set up bearing for the pinion or its gonna get old pressing the bearing off and on.
