Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Gear pattern check
Old 06-06-2011, 02:42 PM
prostreet6t9's Avatar
prostreet6t9 prostreet6t9 is offline
Differential/Driveline
Leave the crush sleeve and seal out during set up and set the correct prelaod. The number on the pinion will do you no good unless your using a depth gauge. If your backlash is too much now,it should bring that coast side down a little when you get the correct backlash. As it sits now it will make noise on Decel.
