Originally Posted by Coolball
It's a GM 10 bolt and I switched the ring and pinion to a 3.42 set of gears and used the same shims to start.
Using the original shims that were correct w/the old R&P are a starting point, but you'd like to start out w/the same shims that were used w/the same R&P you are installing. In other words, if you have the shims that were used w/the 3.42 gears, that is what you want to start with, or the equivalent new shims.
