Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Gear pattern check
  #18 (permalink)
Old 06-10-2011, 05:58 PM
prostreet6t9's Avatar
prostreet6t9 prostreet6t9 is offline
Differential/Driveline
Either one will get you within .010 most times. I would use the shims from the "housing" being used. But then again your depending on the set up being correct if any body has been in there. By that pattern he's pretty close now,just need to see if the coast will come down a little.
