Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Gear pattern check
  #19 (permalink)
Old 06-11-2011, 12:44 AM
Coolball's Avatar
Coolball Coolball is offline
Last journal entry: First Entry 82' Camaro Z28 Project
Thanks for helping out,, whew what a long process!
After many tries I ended up using all the original shims from the 3.42 set as they came out of the donor housing. Back lash is at around .006,, but it's not torqued yet so I assume that will open up a little correct?
How does this look?
ID:	55955   Click image for larger version
