Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Gear pattern check
  #20 (permalink)
Old 06-12-2011, 09:51 AM
HalfOunce HalfOunce is offline
Not sure what you mean by "it's not torqued yet" ...The pinion not being torqued will only change the preload of the pinion bearings. However if the carrier is not torqued this will change the backlash and pattern.. you always want to make sure the carrier is torqued during setup.
