Gear pattern or measurements? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-26-2007, 03:55 PM
So far I've set up 4 ring and pinions by using my gauges, checking pattern , make adjustments, check pattern again etc,. untill I get the proper pattern. No problems or noise. Now I'm setting up a rearend in a 1955 tractor. Because I have limited info. should I just do the trail and error method till I get the proper pattern?
Old 09-26-2007, 09:04 PM
In a word, Yes.
Using gear tooth patterns will always get it right....
Distributor gear removall/installation ssmonty Engine 1 07-04-2007 07:11 AM
drive gear problems-th350 billsnogo Transmission - Rearend 3 06-18-2007 07:07 PM
Is my rear end gear pattern ok? Warrant Transmission - Rearend 1 04-22-2007 09:34 PM
Ring & Pinion Tooth Contact Pattern GM 10-Bolt leejoy Transmission - Rearend 52 12-15-2006 06:26 PM
BBC cam gear problem 454C10 Engine 4 12-14-2004 02:07 PM
