gear question - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-20-2006, 11:34 AM
coop_01's Avatar
New Member
gear question
I am running a 350 30 over with modifide heads, comp 305 cam,flat kieth black flat tops,holley strip dominator single plane intake & a 750 double pumper, in front of a 350turbo with a b&m shift kit with a 2800 to 3200 stall in a 1997 s-10 its got the stock 4:10 gears all i added to it was a possi. locker. so the question is what gears should I run in the rear end because it just doesnt feal like im getting its full potintiel i also have a 3:42 rear end
Old 04-20-2006, 03:10 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
What size tires are you running?
I would say you have a much better potential with the 3.42 gears since you aren't using an overdrive transmission.
You are still going to eventually be plaqued by the 7-5/8 inch axle, as they are generally accepted as being weak.
first post-hello-timing gear question rsrogers Introduce Yourself 2 01-20-2005 12:50 AM
Gear Swap. M&M CUSTOM Transmission - Rearend 3 06-26-2004 05:53 AM
Camaro 10-bolt 8.2 upgrade - gear question EricTopless68 Camaro Transmission - Rearend 0 02-23-2004 09:10 PM
hi, i have a rearend gear question Thuggishruggish3000 Transmission - Rearend 2 08-10-2003 12:55 PM
Hotrodders Guidelines -- READ ME Jon Hotrodders' Lounge 0 06-14-2003 05:08 PM
