gear ratio - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-01-2009, 10:59 AM
gear ratio
OK, problem is driving me nuts...
Car is a '78 Datsun 280Z with a Chevy 350 engine, Turbo 350 tranny, Datsun R200 differential. The rear has a after market device that makes the rear gears lockup much like a posi-traction. Problem is it runs at a high rpm when doing 50 MPH. OK, I turned the drive shaft a little over 3.5 turns to get the wheel to rotate one turn.I would guess than that it has a 3.50:1~ or so rear gear. Why then is it taching high at speed? The tach is not running right now so I would have to guess that at 50mph it miight be running around 3000 rpm.
I've seen plenty of cars with 3.58:1 gear ratios be quite road worthy.
All ideas are welcome.
Old 02-01-2009, 11:34 AM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
what size tires?
Old 02-01-2009, 11:37 AM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
how sure are you that it is a 3.50 gear.sounds lower to me.and tire size does make a differance.
Old 02-01-2009, 12:15 PM
tire size
tirte size is 235 60 R14 and the official gear ratio is 3.545:1
Old 02-01-2009, 01:31 PM
& matts38chev
thats only a 25" tall tire i would try and get somthing a little taller and see if that helps (maybee borrow one from a buddy)
Old 02-02-2009, 11:40 PM
Wiki Edits: 85
When you turned the driveshaft, did BOTH tires turn the SAME amount at the SAME time? If so, your calculations would be correct. If no, then your calculations are wrong.
Old 02-03-2009, 12:21 AM
Joe G's Avatar
By my math, with a TH350 in high gear (1:1), a rear end ratio of 3.545:1, and 235/60-14 tires:
Speed vs. Engine RPM
50 mph @ 2375
60 mph @ 2850
70 mph @ 3325
80 mph @ 3800
Maybe your ear tach is calibrated for a 6 cyl.. (that's a joke)
Is it possible the transmission is not getting into high gear?
Like Matt said, taller tires will help. If you can determine how big of a tire you can fit on the car, I can recalculate and tell you how much it would affect the engine speed.
Hope this helps...
Joe G.
Which gear ratio is best for my cam?? eatonde Engine 7 01-20-2009 05:36 PM
7 hours, 33 phone calls, &30 pages of Threads later... Rearend? Tranny? Need Guidance 68ChevelleFromHell Suspension - Brakes - Steering 19 01-13-2006 01:01 PM
tire size and gear ratio inquiring_mind2 Transmission - Rearend 12 08-17-2005 09:57 AM
What Gear Ratio 79 Malibu327 Engine 5 04-12-2004 11:30 PM
What gear ratio should I use Maverick Transmission - Rearend 1 06-25-2002 08:40 PM
