gear ratio - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-08-2004, 12:16 PM
Silentlion_69's Avatar
Duck Tape & WD 40
Last journal entry: No more Vehicle
gear ratio
okay my 85 GMC Sierra pickup ( 2 wheel drive) will hardly do a burn out, i can rev the thing to the high heavens and it will still barely burn out, could the fact that it has a 2.73 gear ratio have anything to do with it.
Old 10-08-2004, 12:33 PM
gpeak's Avatar
273 gear....what engine??? what transmission? Less power with less gear makes it hard.
Old 10-08-2004, 07:37 PM
Tazz
can't smoke the tires or shouldn't smoke the tires?
Is this possably a V6 engine we are talking about here? Big heavy truck and small engine might just be the problem.
tazz
Rat Rods Rule!
Old 10-08-2004, 11:39 PM
Ghetto Jet's Avatar
current hot rod: CTS-V
Last journal entry: Lets Get Started With the Improvements
Re: gear ratio
You're not revving it up and putting it in drive are you?
Old 10-25-2004, 11:54 AM
Duck Tape & WD 40
Its got a 305 with a 10 bolt rear end
Old 10-25-2004, 01:35 PM
Siggy_Freud's Avatar
2.73 ratio isn't exactly an off-idle performance setup. Of course the 305's weren't exactly a performance engine either. Id say its a combination of both
And like Ghetto said, I hope your not revving it to the "high heavens" and dropping it into drive isn't a great thing to do. You'll eventually find your entire driveline in "high heaven."
Bringing history and technology together.
Old 10-25-2004, 10:29 PM
Old School Nut's Avatar
machinest & A&P Mechanic
Last journal entry: distributer housing...
yeah i would say a combination of your motor, tires (width and hight) and your axle and prolly your tranny... i have a 350 with a th350 tranny shift kit and 2:73 gears... i can cherp em at a stop light. and i can spin a tire around a turn for about 30 feet from a dead stop and thats all she has when i floor it.. not anything special, but she has a rather high top speed for a 1966 chevy 3/4 ton truck.. oh and my tires are 29 inches tall... and i can go over 100 in her..
Old 10-26-2004, 06:11 AM
Duck Tape & WD 40
what would be a good ratio if I was to change it?
