Gear Ratio change - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-08-2003, 11:21 AM
Post Gear Ratio change
How do you do a gear ratio change? For instance, right now I'm running a 3.66:1 posi differential and if I just get under her (1978 Corvette) and take off the back housing of the differential, how hard would this be? Maybe change to a 4.11:1?
Maybe not, though. She's not a daily driver, but she's also not a racer. And I do want to keep her as stock as possible, so I don't want to do anything irreversible. I just want a little more acceleration from a higher ratio. But then again, I don't want to stress the engine too much (when I go on the highway with 4000+ RPMs) and be too inefficient.
Any ideas or thoughts on this subject?
Thanks!
TR
Old 04-08-2003, 07:53 PM
bigwildgrin's Avatar
Rooster
Post
how hard would this be? well, pretty hard if you have never done it before. my first rear end change was a nightmare; the whole rear axle out and disassembled three times before I got it right. take it to someone who knows, and even better take it to someone who knows and will show you. I personally believe it's almost an art; I have a buddy who does it for a living and he slaps them in and sends them out the door so fast your head would spin. for me it's a weekend project.
I don't recommend going this way, but, you can also buy the whole assembled carrier unit. Chicago Corvette sells them complete and rebuilt, and I don't want to sound like a commercial for them but last time I checked they were $375 plus your differential, or $825 without. changing the differential isn't hard, just some general mechanicing. any corvette differential from 68-79 will fit (all are posi).
as for my opinion on what you should do, I have a '68 vette with 4:56 gears and I would trade you in a heartbeat. sure it will go from zero to 60 in the wink of an eye (in theory anyways, if you could ever get the tires to hook up), but with a four speed it's just too much. your shifting constantly and you can almost start out in fourth gear. take my advice and keep your gears; if she doesn't have enough ummph for you, you'll be happier if you spend that money on the engine. as for me, I'm holding out until I find a set of 2:77. the speedometer goes to 160, seems like the car should too.
Old 04-09-2003, 04:50 AM
Post
Okay, I agree with you. I'm just going to keep my current ratio. She has good acceleration, nothing that I'm unhappy with. just a thought. I see what you mean about starting in 4th gear.
Thanks!!
TR
Old 04-10-2003, 07:17 PM
redcamaro4spd's Avatar
drive it like you hate it
Post
I got a set of 2.73's out of a 1977 Camaro, I dunno what rear end size you got, but I'll sell them to you...lol
I desperately need a set of 3.73's...
Old 04-11-2003, 04:35 AM
Post
Well I have a 3.36 so I wouldn't want to go backwards to a closer ratio, I was thinking something more along the lines of closer to 4. But I decided against this mod. Thanks anyways!
TR
Old 04-11-2003, 07:01 PM
Post
I have done many vettes and its no big deal to drop the rearend, but as others have suggested it's hard to change the gears if you haven't done it before. You may also look around for a complete used diff with the right gears. 3:73 is perfect for street vette. I have had the most success with a 3:36 and a 700R4 trans. I just did a 74 and installed the 700 trans with the lock up converter. Very easy swap and the car flys with a 350 hp small block. good luck.
