Hotrodders Bulletin Board
#1
Gear ratio info needed
I have access to a rear end from a '77 Buick Skylark that appears would fit easily into a 52 Chev PU. am wondering if anyone might know what theBuick ratio might be. The Buick was an A.T. car, but don't know what engine. I have no idea what was available in those cars. ???? Any help is appreciated.
#2
EASY...........pull the cover off the rear end and count the teeth.......divide the big number by the small number.........and that's your ratio.....
Old age and treachery will overcome youth and enthusiasm every time. |
#3
If you pull the cover, you should find two numbers stamped on the ring gear. One is the number of teeth on the ring gear, the other is the teeth on the pinion. Divide the smaller number into the larger.
#4
If for any reason you can not remove the cover, rotate the pinion and count the number of turns in relation to 1 revolution of the axle. IE: 2.5 turns of the pinion to one of the axle is approx 2.50 ratio. 3.75 turns approx 3.73 ratio etc.
A wild guess it will be in the mid 2's |
#6
The '77 Skylark is just a Nova with soft springs & different trim. Scroll down almost to the bottom & you'll find a chart of what ratios came with what engine/trans combos in '77, along with some axle codes.
http://novaresource.org/axle.htm |
Back to top |
Similar Threads for: "Gear ratio info needed"
| Roller cam/distributor gear information | Jmark | Engine | 0 | 12-29-2003 03:56 PM |
| How to tell gear ratio??? | maddmaxx | Transmission - Rearend | 20 | 11-29-2003 07:43 AM |
| Gear ratio | Mirror Image | Transmission - Rearend | 2 | 02-28-2003 11:00 AM |
| RPM, GEAR RATIO , TIRE SIZES, EQUATIONS | zonk | Transmission - Rearend | 1 | 01-08-2003 10:16 AM |
| chnging gear ratio | RAYRAY | Engine | 5 | 10-21-2002 02:22 PM |
