gear ratios in a 4x4 front vs. rear.... - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-14-2005, 11:14 PM
crazy larry's Avatar
Last journal entry: better comparison before and after shots
so... I'd always thought the front and rear differentials had to be the same gear ratio. I've discovered i have a dana 44 front with 4.10's, and a danged chrysler rear with 3.55's.... and it was the rear that was smoked. not that i didn't discover that until after i replaced the front carrier bearings.... so, does the gear ratio need to match?
Old 04-15-2005, 12:25 AM
what?
yes, they need to match,unless your runnin big mud then sometimes guys run a taller gear up front to spin faster keepin the front up.
Old 04-15-2005, 03:40 AM
poncho62's Avatar
Wiki Edits: 5
Somebody has obviouslly changed either the fronts or rears....
They need to be the same. Usually, the front is slightly shorter, so that it pulls away a slight bit from the rear, so they don't bind........like 4.10 front and 4.11 rear.
Ontario Rodders
Old 04-15-2005, 07:30 PM
broncoII88's Avatar
Do the right thing...
If the ratios arent the same, then both sets of wheels will spin at different speeds. Which will cause damage like you mentioned.
Different rear gear ratios = ?? 84Z Transmission - Rearend 5 06-24-2004 01:14 PM
Cam and rear gear ratio with blower??? 84Z Engine 4 05-29-2004 07:22 PM
Rear gear difference Meangreen Transmission - Rearend 4 05-25-2004 05:46 PM
rear end gear swap Jared Engine 3 03-19-2003 08:46 PM
Old olds rear ends Front loader roys63 Transmission - Rearend 1 02-12-2002 12:10 AM
