gear ratio's '68-72 f250 rear's - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-10-2013, 08:51 AM
delawarebill's Avatar
ck'd a few places and i don't see what the factory offered or what usually comes in these rears.. i'm tossing around of changing the rear in my F2, but if it comes with 4 something gears and i gotta change them to low 3's then it may not be worth the change...
Old 06-12-2013, 09:53 AM
It would probably be a 3.54 or 3.73. Those years would be a Dana 60 rear 16 spline. If you could I'd look at putting a newer 60 rear in it that was 30 spline full floater like a late 70's f250. As long as the width is correct for your truck.
Thanks,
Bobby
Need help choosing rear gear ratio 6D9CMRO Transmission - Rearend 8 01-20-2012 09:19 PM
Rear gear ratio ? newportman Hotrodding Basics 3 02-14-2011 09:04 PM
Rear end gear ratio change = spedo. cable gear change. help? turbo 350 sugar ray Transmission - Rearend 6 07-18-2007 12:32 PM
rear gear ratio with 700R4? 68firechicken Transmission - Rearend 4 08-06-2006 01:58 PM
rear end gear ratio mechanix54 Introduce Yourself 2 02-22-2006 12:22 AM
